Well I got busy the last couple of days, so I have some new pictures of my 440. It is completly a-part and today was cleaning day. I loaded the motor, finals, trans, bell housing and reverser case in the back of my pick-up and headed to the steam cleaners. I have to say it was one heavy load. Monday I plan on sand blasting and a coat of primer on everything but the engine. I brought it back with me to set up on the engine stand to start tearing it down. It is nice to see all the grease removed. I have found a few problems.
Here are several views of the 440 disassembled.
Here's the power plant.
Here are a few of the problems.
A damaged Trans. Case.
Damaged seal in left final. Notice all the gear oil.
Chipped Pinion Gear. This too was in the left final.
Damage to throw-out bearing in the right steering clutch.
When I looked through the spline hole from the left to right steering clutch I found this spring, I'm guessing it doesn't belong there. Any ideas?
Right steering clutch housing. Needs seal replaced.
And finally the bear under carriage.
Hope you guys enjoyed it.
When you guys primer your parts, is there a special primer you use?
Craig
