Finally! here is Berta
isn`t she ugly?
Thank you jdemaris for the tip, tried to do the same thing using MSN, but my computer "jammed" all the time, i had to reboot it and got nowhere.
All the Bosch's came from the same origin. Just turned into a legal mess down the road. American Bosch (formerly AMBAC), Joseph Bosch, Charles A. Vandervell (CAV), Simms, Lucas, ConDiesel, and Rotodiesel are all tied together.digitup2 wrote:Just so you know Bosch and Robert Bosch are two different entities as well .Robert Bosch is North American Market injector system components .Bosch is European built systems .
.The big problem was typically it took John Deere five years to figure out that there was a problem .So you sure never bought the first of the new model upgrade I bought several used units then and the previous owners would mention they would trade the new crawler for the old one back .It was well known that the E in 450E was for Excuses Deere didn't make these for long for a good reason although the engine was a great starter if you got the right one .Digitup.
No. Metal disks were the heavy duty option and cost more. Now it is all Deere will sell you. They are still available from Deere and aftermarket. $35 aftermarket, and over $100 each from Deere. Some other tractor companies made them standard equipment, but with Deere, it was a high-priced option until recently.D557017 wrote:In the picture you can see one clutch disc from the right and left side, one is all made of "clutch material" the other is metal with the clutch material on it.
The metal one was on the right hand side, is that an older version?
Aftermarket disks are available both ways - fiber and metallic.D557017 wrote:Hello jdemaris, by the prices it sounds like the aftermarket would be preferable for me.
Are the aftermarket clutchdiscs metallic to, or do they have both kinds?
Can the other parts i need be found on the aftermarket to?
(brakebands, throwout bearing, brake return springs, gaskets etc.)
Could you recommend me a company that might exist in Europe?
Thank you
You'd be better off with the newer style seals used in the 450Cs. They hold much better in a worn adjuster cylinder. Very easy to cut the groove a little wider in the piston to let them fit. It was standard procedure for any 350 or 450 we fixed in our shop.D557017 wrote: -The track tensioner seals for both sides
the steering presssure plate springs T25049T, and one of mine are broken so i really need springs for one side.
That is the common problem of having a machine that is NOT common where you live. I just had to order some parts for and older Stihl chainsaw from a guy in West Germany since the parts are not sold in the US. Also, just ordered a new carburetor from England for my International Harvesster tractor/backhoe. That, because it uses a British Zenith VN carb - not related to Zenith in the USA. Only common overseas.D557017 wrote:
About pressure plates being available all over the place, well that might be the case in the USA but unless the same plates are used for something else, i dont think they are all that common in Sweden.
I know of only one other old JD 450 here.
Users browsing this forum: No registered users and 312 guests
