gus
Post
by gus » Fri Dec 19, 2008 7:02 pm
Yeah right
I'm moving snow with a small 4wd JD with a back blade and loader right now but it's getting too deep. I'm in the early repair/rebuild work on my 420 and plan mounting a 6 way blade on it. There's no way it'll be done this year so it looks like I'll have to start the D-4.
I have a 1/2 mile drive to keep clean and it is in the mts and on a hill side. I DO NOT get to close to the edge with a tractor.
To my original question. When I have the 420 (5 roller) and 6 way blade operating, how will it compare to the D-4 (straight blade)?? I know it is much smaller and lighter. How are they for traction on hard packed snow??
When the 420 is running, the JD wheely will probably not be used except for around the shop and garage where I sometimes have to bucket it over the rocks on the edge. This will eliminate the problem of the shrinking drive as I can't push snow out past the previous berm. I'll be able to keep the whole drive cleaned off.
One really nice thing about my new shop is I will be able to keep it inside and always warm. It can share space with the JD wheely. I just hope they can get along
brettjones
Post
by brettjones » Fri Dec 19, 2008 8:43 pm
Weather in my part of Maine has been all over the place this month, but looks like it's finally settled into winter. We have 4 or 5 inches on the ground and expect a pretty good amount this weekend. I grew up in Western Washington and my sister tells me they go a huge amount in the Arlington area. Snow in the Seattle to Everett area was always "fun".
I keep the homestead clear with an old (1986) 1 ton 4x4 and a 9' plow. Last year we had a lot of snow and I managed to pile up a 6' tall by 15' by 35' "mountain" of snow for the kids to play on.
Enjoy your white Christmas Gus.
JD 1010c, outside blade, winch
- Site Admin
Post
by Lavoy » Fri Dec 19, 2008 8:52 pm
We got 10" give or take last weekend, but with 30-50 MPH winds for 30+ hours, it is kind of hard to tell. The lawn is almost bare, the trees have 3 feet or more. Predicting 3-7" for this weekend, but not as much wind, hope it comes down nicely and covers everything up.
A 420 will not push with a D4 in a straight push, just not as much power. That being said, I think in certain conditions, a good 420 with a reverser will probably outwork the D4 in terms of work done depending on the area you are working in. Especially if you angle the dozer to clear a driveway, then they are slick. I'm using an MC right now until I get the 1010 up and running, but have used a 420 in most of the preceeding years up til now.
gus
Post
by gus » Sat Dec 20, 2008 1:38 pm
Well, it's 12 degrees out, the suns out and it's a nice day. The D-4 battery is on the bench hooked to the charger. Time to crank it up and clear the drive. There is a storm watch on for Sun with 12-18" more on the way so I better clear it while I can.
Get ready Lavoy it's headed your way.
Gus
snoopy
Post
by snoopy » Sat Dec 20, 2008 1:51 pm
Been snowing on and off for a weeek. Getting tired of it. need to blade driveway again, had to chain up to get back to the this morning. Not taht much snow, but combined witha steep driveway, it get bad will snow all day today, then change to freezing rain. Got abgout 12 inches total. A lot for here west of Portland Oregon. MC works good for snow!!
1949 MC
"If it ain't broke, don't fix it"
Post
by Ray III » Sat Dec 20, 2008 4:37 pm
I used my 420 in snow a couple times. You'll run out of power before you run out of traction. You can run it up the side of a snow pile though since its footprint is light as a feather. I doubt the D4 would be able to stack snow as high.
Post
by Ray III » Sat Dec 20, 2008 4:39 pm
Are you talking a power 6 way blade or the manual model 62 blade?
Just wondering if anyone has ever modified a blade off a 440 to fit a 420.
gus
Post
by gus » Sat Dec 20, 2008 6:33 pm
Ray III wrote:Are you talking a power 6 way blade or the manual model 62 blade?
It is an after market "noname?" (came off of a 420). It has 4 way power, not on the angle, but I'm considering adding it when I mount it. A little welding and another cylinder would make it into a power 6 way. A really neat feature is that it has wings that swing out when it's angled. Perfect for snow. The blade is an inboard mount and needs some minor work and the hyd rebuilt but it's in good shape overall.
gus
Post
by gus » Sat Dec 20, 2008 8:28 pm
I decided not to have breakfast on the deck this morning...............
snoopy
Post
by snoopy » Sat Dec 20, 2008 9:55 pm
Pushed powder with MC for a couple of hours tonight. Lots of fun. Neighbor thouhgt they JUST had to get out. About 15 inches or better right now and snowing hard.
1949 MC
Post
by Ray III » Sun Dec 21, 2008 7:54 am
Wings would definitely be great, on flat ground the crawler is kind of overkill for only a 6' blade and you have to chase snow everywhere. It would easily clear an 8' path of snow in 4th gear (5 speed transmission) and if it got too deep you can always downshift.
brettjones
Post
by brettjones » Mon Dec 22, 2008 12:06 am
We're getting a pretty good dump of snow right now. I'd guess we're close to 12", but the wind is blowing it around so it's hard to tell. I cleared the drive and the areas around the house and shop twice in the last 6 hours, but you'd never know to look at it.
KenP
Post
by KenP » Mon Dec 22, 2008 5:44 am
deleted
KenP on Thu May 16, 2013 6:22 am, edited 1 time in total.
Dave Seager
Post
by Dave Seager » Wed Dec 24, 2008 6:57 am
KenP wrote:Likewise, we got a good amount of snow overnight... on top of the 12 inches we got two days ago. With the wind (presently gusting to 25-30 mph and the temps in the single digits, its blowing and drifting all over.
Looking out the window, it looks like its about 12 inches in some places and easily triple that in others. Wind chill right now is -7F.
The Plan is to relax, have a great breakfast, and wait for the skies to lighten a bit. Then, its plow time...
We had that record ice storm last week and went without power for 6 days.... we're back on the grid but many are still out and are being told maybe another week! Local authorities are urging folks to find shelter at warming centers but many of the crusty New Englanders are staying put.
So, yep, we got snow!
KenP
Ditto over here in New Boston.
Got our power back at 6:10 Tuesday night and consider ourselves VERY fortunate!
I ran our 8.5KW generator non stop from Friday AM to Tuesday PM @ $1.00 per hour for gasoline!
We lived normally except for the clothes drier!
Man, I HATE sctatchy towels!
I've been re-arranging flakes the last couple of days as well as working on fire wood.
Dave
- Site Admin
Post
by Lavoy » Wed Dec 24, 2008 10:22 am
We got another shot here last two days, but nothing like some of you guys. We supposedly have a foot and half or so, but most of it came sideways the first time, so who knows.
