MC FAN BELT
snoopy
MC FAN BELT
Post by snoopy » Sun Nov 30, 2008 5:12 pm
I AM TTRYING TO TIGHTEN THE FAN BELT ON MY MC AND CANNOT GET THE NUT LOOSE. ANY IDEAS ON HOW TO HOLD THE SPINDLE FROM TURNING WHILE TRYING TO LOOSEN THE NUT.
THANKS
BOB
1949 MC
"If it ain't broke, don't fix it"
MikeT
Post by MikeT » Mon Dec 01, 2008 12:39 pm
There should be a hole that a roll pin would fit in or a roll pin punch to hold shaft.....be carefull not to break the punch or the flat washer when you retighten.
snoopy
Post by snoopy » Mon Dec 01, 2008 2:01 pm
would that hole be just aft of the belt pullys? I was looking for flats or holes but have not found anything yet. will go back out and look again.
Thanks for the help
Bob
1949 MC
Post by Lavoy » Mon Dec 01, 2008 2:26 pm
I think it is through the shaft in the area of the shaft that is in the slot in the bracket.
snoopy
Post by snoopy » Mon Dec 01, 2008 2:33 pm
OK, that is the only place that I haven't looked, will do some more cleaning and look there .
Bob
1949 MC
snoopy
Post by snoopy » Mon Dec 01, 2008 5:56 pm
Lavoy, found the hole where you said, but someone in the distant past broke off something in it. I decided that a loose belt will be easier on the bearings so left well enough alone. At least for now.
Thanks for the help
Bob
1949 MC
Post by Lavoy » Mon Dec 01, 2008 7:54 pm
Bob,
I have in the past on a 40, very carefully pry upward on the nut and was able to get the fan to slide upward enough to tighten the belt.
snoopy
Post by snoopy » Mon Dec 01, 2008 9:42 pm
Lavoy, Will see if I can try that. It is pretty low, don't know if I can get under it. With all the pentretrating oil I have on it, it just may slide a bit.
Bob
1949 MC
Users browsing this forum: Google Adsense [Bot] and 231 guests
