........A standard hand operated grease gun doesn't budge em ! Any ideas for a simple remedee ? ?
Thanks .............Sandman92284
1010 C .........Stuck track adjuster/s
- sandman92284
I'm not sure where your adjusters are stuck in relation to the travel on the trackframe, but if not fully retracted you may be able to push on the front idler with another piece of equipment to get them to budge first and then see if grease gun will work. You need to be sure that the plug is removed to allow grease to escape and be very careful pushing on the idler so you don't damage something. I got one of my adjusters on my 2010 to unfreeze by doing this.
- Paul Buhler
Track adjustment.
Have you swapped out the grease fitting? Sometimes the problem is there. Paul
- sandman92284
To all the guys that responded to my question,"easy fixes for stuck adjusters " ! A big THANKYOU !
I'm going to try all of your suggestions, , , ,I'll let you guys know witch one does the trick !
P.S I'm new to "JD Crawlers Message Board" , I accidentally duplicated my question ! Please disregard !
Thank You ,Dennis Brown
Yucca Valley CA
Yucca Valley CA
Users browsing this forum: No registered users and 156 guests
