1010 C .........Stuck track adjuster/s
sandman92284
Post by sandman92284 » Sat Nov 15, 2008 11:57 pm
........A standard hand operated grease gun doesn't budge em ! Any ideas for a simple remedee ? ?
Thanks .............Sandman92284
Post by Lavoy » Sat Nov 15, 2008 11:59 pm
A good lever gun will do 6,000-10,000 PSI, not sure what else you could try. Only thing comes to mind is a power pack off of a porta-power, but they are 10,000 PSI give or take too.
Post by Tigerhaze » Mon Nov 17, 2008 10:32 am
I'm not sure where your adjusters are stuck in relation to the travel on the trackframe, but if not fully retracted you may be able to push on the front idler with another piece of equipment to get them to budge first and then see if grease gun will work. You need to be sure that the plug is removed to allow grease to escape and be very careful pushing on the idler so you don't damage something. I got one of my adjusters on my 2010 to unfreeze by doing this.
Track adjustment.
Post by Paul Buhler » Mon Nov 17, 2008 6:03 pm
Have you swapped out the grease fitting? Sometimes the problem is there. Paul
sandman92284
Post by sandman92284 » Thu Nov 20, 2008 11:03 am
To all the guys that responded to my question,"easy fixes for stuck adjusters " ! A big THANKYOU !
I'm going to try all of your suggestions, , , ,I'll let you guys know witch one does the trick !
P.S I'm new to "JD Crawlers Message Board" , I accidentally duplicated my question ! Please disregard !
Thank You ,Dennis Brown
Yucca Valley CA
Post by Lavoy » Fri Nov 21, 2008 8:58 am
If you look in the upper RH corner of any of your posts, there is a delete button.
Users browsing this forum: No registered users and 178 guests
