1010 reverse
ritchiegilby
1010 reverse
Post by ritchiegilby » Tue Nov 11, 2008 3:32 pm
hey guys
got a 65 1010 gas it pops out of reverse unless i hold my hand against the gear shift, otherwise works great. any ideas, it is a manual tranny
ritchie
Post by Lavoy » Wed Nov 12, 2008 8:35 am
Sounds like a bad bearing or two. Pull the top cover and look at the gears, wiggle on the shafts with a pry bar, that may show you what is bad.
ritchiegilby
Post by ritchiegilby » Wed Nov 12, 2008 8:49 am
is that an "easy fix" or is that a break in half job if i find the problem through the top case
Post by Lavoy » Wed Nov 12, 2008 4:11 pm
If it is a bearing, then it is a break it in half, pull both finals, gut it to an empty case fix. :cry:
