1010 track frames
brettjones
1010 track frames
I've moved my 1010 into the shop and started tearing it down. It's obvious the machine has been used hard over it's life. The mounting plates for the outside blade have been hacked up a fare amount and one side was welded to the track frame. The track frames have been repaired more than once and are going to need major surgery or replacement. One has a bit of a twist in it.
I'm curious what a set of good 4 roller frames are going for now a days? Ditto on inner and outer roller and sprocket guards for a 4 roller machine (Mine are long gone)?
JD 1010c, outside blade, winch
brettjones
I have not, doesn't mean it can't be done. The problem I see will be if they can bend in a radius like the original instead of a tighter bend like most places will do. I would go to a place that bends truck frames regularily, they will have some better steel to use, do not use just mild steel. When I worked in a truck frame shop once, the local tank manufacturer used to bend frame sections for us.
- john lewis
brettjones
- john lewis
- john lewis
