New reproduction rockguards
Post by Lavoy » Mon May 19, 2008 4:33 pm
Is anyone interested in a set of new reproduction rockguards for 420/430? I made up a set of 4 roller, long trackframe guards today. I am going to make 5 roller guards as well, hopefully in the not too distant future. I will get a pic of the 4 roller guards posted shortly.
Tractor 850
Post by Tractor 850 » Fri May 23, 2008 8:14 am
Will the 5 roller guards also work on a 440?
Dave
JD440IC Ser#445235 W/ #63 Dozer
Ford 850 Ser#55497 W/Wagner Loader
Post by Lavoy » Fri May 23, 2008 4:18 pm
No, they would be too short. If there is enough demand, I may tool up 440 rockguards next, but want to finish the 420/430 first.
Tractor 850
Post by Tractor 850 » Fri May 23, 2008 4:49 pm
If you have them I'll take a set.
Dave
Charles
Post by Charles » Fri May 23, 2008 6:20 pm
I'd also like a set for the 5 roller. Thanks Charles
Post by Lavoy » Fri May 23, 2008 7:54 pm
I need to do some more tweaking on the 4 rollers before I get into the 5 rollers. They looked good, but there is a slight difference in one radius that created a clearance problem. Should be fairly easy to correct.
