New voltage regulators
Post by Lavoy » Fri Oct 21, 2005 8:29 pm
Just in, new voltage regulators for 40-440 gas, $35 + freight.
Jeff Clark
Post by Jeff Clark » Sun May 04, 2008 7:53 pm
Lavoy ,my 40c crawler ,have to jumper wire coil to operate tractor ,tested wireing ,cannot get power to ignition switch, is power supplied from regulator to switch? , regulator has power from battery for generator ,charging system works perfect,tractor has no electric features except basic generator and coil jeffvanguardclark@yahoo.com or jeff clark on this message board thanks JEFF
Post by Lavoy » Mon May 05, 2008 9:28 am
The power goes through the ammeter first then to the switch, check you wires there too.
Tractor 850
Post by Tractor 850 » Mon May 05, 2008 11:15 am
Jeff,
Check the ammeter as well.
It should have almost no resistance when checked with a multi-meter.
Would a JD voltage regulator work on a Ford 850 with a 6 volt positive ground system?
Dave
JD440IC Ser#445235 W/ #63 Dozer
Ford 850 Ser#55497 W/Wagner Loader
Jeff Clark
Post by Jeff Clark » Mon May 05, 2008 7:09 pm
Lavoy ,thanks for the reply ,i will check the amp meter in the morning ,maybe the wires broke long time ago, Jeff
Post by Lavoy » Tue May 06, 2008 9:34 am
Dave,
I can't find a listing for the 850, but all of the other 6 volt fords use a different mounting style than the Deere regulator. There should be no problem getting the correct regulator for your Ford if you want one.
Tractor 850
Post by Tractor 850 » Tue May 06, 2008 11:54 am
I can find Ford regulators but the quality is horrible.
I thought that you might have a better source.
Dave
Post by Lavoy » Tue May 06, 2008 3:06 pm
I do, yes. I have been getting some different brand regulators. I have been trying them on my stuff first, and they have been working great. They are quite pricey, but still cheaper than OEM. Unless you are having a problem with the other regulators, they are probably not worth the extra cost. I have put them on a couple of crawler that have been problem children for as long as we have had them. Finally put rebuilt generators, new light switches, and these regulators on them and solved the problem, at least for now.
