jd 350b popping out of reverse
sniezek66
Post by sniezek66 » Mon Mar 17, 2008 7:20 pm
hello guys , new to the site and i think it's great! Now hopefully you can help me out. recently did a major overhaul on our 1973 350 b crawler. We replaced the gas engine with a diesel, new steering clutchs (complete) and new main clutch (complete). It sat for 14 years in a garage and when we took it out for a test we noticed that it would pop out of reverse under and load or moving at high rpm. It's even hard to hold into reverse when it pops out. Is there something wong internally, or is something frozen or misadjusted? Any help would be great, we have alot of time and money into this and want it to be working correctly.
thanks
kurtis
Post by Lavoy » Mon Mar 17, 2008 9:50 pm
I would guess a bad bearing, or the gear itself is tapered.
pdmech08
Post by pdmech08 » Tue Mar 18, 2008 12:20 pm
I would have to agree with Lavoy. Either a bad bearing, which would allow the shaft to move end to end, (as well as up and down) or a worn gear. Although....... if it were a bad bearing it seems you may have trouble with other gears as well. Steve.
sniezek66
Post by sniezek66 » Tue Mar 18, 2008 1:48 pm
does that involve removing the hole transmission or can i get to that by removing the top cover where the shifter goes in? This crawler does not have reverser either.
sniezek66
also i'm not having trouble with any other gears.
Users browsing this forum: Google Adsense [Bot] and 41 guests
