Need HLR Clutch Packs
jgbanshee
Post by jgbanshee » Tue Mar 11, 2008 2:26 pm
Is it cheaper to repair or replace the clutch packs in the tranny of my 450 crawler? I figured out that the hub immediately in front of my low/reverse clutch pack free-wheeling when I put the tranny in Reverse. I think due to the inner diameter teeth on the plates in the clutch pack broken. I got 150psi on the gauge in every range when pressure testing initially. Should I replace all the other clutch pack plates during this time?
Post by Lavoy » Tue Mar 11, 2008 3:30 pm
If you don't mind doing the work, probably cheaper rebuilding your own. As long as you are in there, fix it right so you don't have to go into it again.
jgbanshee
Post by jgbanshee » Tue Mar 11, 2008 8:24 pm
Where can I get new parts for the clutch packs? What is a reasonable price?
Post by digitup2 » Tue Mar 11, 2008 8:59 pm
If you have the part numbers look at the ag dealers as well as the industrial dealers .Replace the piston seals as well as the shaft seals if piston is woren down in seal area be prepaired to replace it also.I always figure that it is enough work to get there just replace anything that is in need of replacement .Check the steel Plates for warping on a straight edge .When they get hot they will dish like crazy and need to be replaced if not perfictly flat .Digitup.
Post by Lavoy » Tue Mar 11, 2008 9:10 pm
I have at least some of the discs availalbe, maybe all of them. When you get the part numbers you need, e-mail them to me, and I will check on pricing.
jgbanshee
Post by jgbanshee » Wed Mar 12, 2008 5:37 am
Here are the part numbers that I am expecting to replace.
R32692
R57345
RE23000
R90644
R33246
R27789
R46218
I have to figure out the quantity of each part number still.
Users browsing this forum: Google Adsense [Bot] and 208 guests
