440 Track Master Link
jac
Post by jac » Fri Oct 07, 2005 6:17 pm
This should be simple, but am having trouble removing the pin from the master link. I have removed the snap ring and have tried to drive the pin out as per service manual. No luck. Soak it in PB Blaster, no luck. Have hit the pin using a 1.5" drive pin and a 5 pound hammer. No luck. I have not mushroomed the pin, but this thing is being very difficult. Suggestions?
Post by Lavoy » Fri Oct 07, 2005 9:01 pm
Heat the link around the pin on each side, that will relieve some pressure.
jac
440 Master Track Link and Final Removal
Post by jac » Sat Oct 08, 2005 8:04 am
Lavoy;
Thanks. Heat did the trick. Clink pin came out fairly easy.
Another question. For a 440 Loader, do I need to remove the right fender and hydraulic value/fittings/hoses to remove final? Some of the hydraulic fittings, especially the metal "T" fittings look like they are not in the best of shape. Removal will likely mean replacement. Some of the hoses obviously need to be removed, just need to know if the entire fender needs to come off. No hydraulic leaks so if I can leave most of them alone, they should be fine.
Post by Lavoy » Sat Oct 08, 2005 8:40 am
If not removed, then at least held up by something to keep it out of your way. If you can get it out of the way far enough, then you can suspend the final from something to help hold it.
jac
Post by jac » Sat Oct 08, 2005 5:40 pm
Lavoy:
Thanks for the information. Will start taking the final off tomorrow. Left side looks easier but I will start with the right side anyway.
Users browsing this forum: No registered users and 36 guests
