10/10 reverser
Als-your-pal
10/10 reverser
Post by Als-your-pal » Thu Apr 21, 2005 4:11 am
hi all
i'm have trouble with my reverser it wants to go both ways at the same time.. i'm looking for info manuals etc..thanks Al
ps thanks Lavoy for redirecting me here...
Post by Lavoy » Thu Apr 21, 2005 8:44 am
Look on E-bay, there are usually some manuals on there cheaper than new.
I might have a service manual, will have to check.
bent
manual
Post by bent » Thu Apr 21, 2005 9:39 pm
Al, I know there is different operating manuals, depends on your serial number. I have the earliest two, but not the one I need for my crawler which is late serial numbered. Will sell.
bent
Als-your-pal
Post by Als-your-pal » Thu Apr 21, 2005 10:08 pm
so where do i find this sn #
Al
bent
ser no
Post by bent » Fri Apr 22, 2005 8:50 am
Someone correct me if I'm wrong but I think look on the bell housing behind the engine, LHS. I have a wreck that has the plate in front of the engine, RHS
If you get stuck, I alos have an extra parts manual for 1010C too, will sell, cheap but good and nice.
bent
Als-your-pal
Post by Als-your-pal » Fri Apr 22, 2005 9:26 am
theres nothing on the reverser but on the block carb side under manifold is a number stamped into the block 15337 with an "x" under it?
/thanks Al
bent
ser no
Post by bent » Fri Apr 22, 2005 9:51 am
Al, where's the gear shift - Dash or floor?
bent
Als-your-pal
Post by Als-your-pal » Fri Apr 22, 2005 9:57 am
for the trans mission its on the floor for the reverser it on the left of the dash ..
Al
bent
ser no
Post by bent » Fri Apr 22, 2005 10:12 am
If that is the case then 15337 is definately NOT serial number.
bent
Als-your-pal
Post by Als-your-pal » Fri Apr 22, 2005 10:17 am
i'll snap some photos tomorrow and then u can point me in the right direction..thanks Al :D
Als-your-pal
Post by Als-your-pal » Fri Apr 22, 2005 12:38 pm
bent
how about on the side of the reverser T15879T..
THANKS aL
bent
ser no
Post by bent » Fri Apr 22, 2005 2:53 pm
Al, that's not a serial number, that's a part number, probably of the reverser case. I don't have a book here so I don't know, I just know your serial number will be up around 20,000 plus if the shifter is on the floor. Your serial number, if it still exists on the machine, will be on a plate riveted to something and should say 1010 first.
I can send you some pics.
bent
Als-your-pal
Post by Als-your-pal » Fri Apr 22, 2005 4:40 pm
ok bent...after some dirt removal i found it.....10/10c 27885
al :lol:
bent
serial number
Post by bent » Sat Apr 23, 2005 9:13 am
Al, that sounds right, the shifter moved to the floor at 21,901. I have an op man that will work, cover is missing and some of the pages are ripped but overall, not too bad. It is the worng one for my crawler. The parts man is near perfect. I don't have a service manual but they are available. If you want them, send me an email with your address.
bent
bent
1010
Post by bent » Sun Apr 24, 2005 9:51 am
Hey Al, check out this item on eBay for your 1010
Item number: 7510650783
bent
Users browsing this forum: No registered users and 32 guests
