420 track
bulldozerman
420 track
Post by bulldozerman » Tue Dec 11, 2007 2:23 pm
How tight should my tracks be for my 420c ?
Post by Lavoy » Tue Dec 11, 2007 3:34 pm
About an inch and a half of sag give or take.
TI420
Post by TI420 » Wed Dec 12, 2007 9:23 am
I guess I'll throw my 2 cents in even though Lavoy is the expert and has the most experience - my personal experience is "it depends"...
I did some repair work this Summer and adjusted the tracks to about one inch of sag and went off for a test drive... Didn't get very far and threw one track off the bottom rollers on uneven ground.
It seems that if your pins and bushings are very worn (I'm leading the pack in this regard..), then you get what is called "the snake" - which means that if you lay the track out on the ground, you can curve it side to side because there is so much slop in the bushings. When this is the case, it seems that tighter is better - and I have heard guys on here say, "as tight as you can get them" - but that makes me afraid of breaking something - like the curved upper idler bracket...
What I ended up with is getting them pretty tight without much sag at all, but making sure that at rest, my tensioner springs are not at all compressed, and it makes me feel a little better also if I can lift thr track off the upper idler with my hands - althought not too easily...
In the end, roller and pin and bushing wear seems to be the real key versus tension if you are starting to throw tracks. I can see where if i DID NOT have "the snake", it would be a heck of alot harder for my track to wander off the bottom rollers, because when you are moving around, it doesn't seem to take too much effort for the tensioner springs to get pushed in - even though at rest it seems like it would take alot...
That's kind of a ramble, but maybe helps to lend some insight - I thought tightening would be my solution, but with the existence of "the snake", I seem to have a "1st gear crawler" until new pins and bushings come along...
Hope this helps! - Chuck :-)
Post by Tigerhaze » Wed Dec 12, 2007 11:49 am
I've had to keep my 2010 tracks a little tighter than the book specs for the reasons that TI420 described; I have a really worn undercarriage and got tired of reattaching thrown tracks. :lol:
Post by Ray III » Sat Dec 15, 2007 8:55 pm
Lavoy wrote:About an inch and a half of sag give or take.
That is what my operator's manual says for 4 roller tracks, but for 5 roller tracks it's only 1/2" to 3/4" of sag on each side of the upper roller because the upper roller reduces the span and consequently the amount of droop with a given tension.
Post by Lavoy » Sun Dec 16, 2007 11:15 am
I shoud have qualified my post sorry about that. One other consideration is that there are two different upper idler supports, the older style that is curved, and the later straight style. With the straight style, the sag will not be uniform.
Users browsing this forum: original possum and 34 guests
