3315 Winch value?
dustin502
3315 Winch value?
Post by dustin502 » Sun Jan 16, 2011 2:51 pm
I came across a guy with a 3315 winch and I need some advice on a fair value. The guy said the winch has been sitting in the weeds close to 15 years so I'm sure it is in poor condition. My 350B isnt set up for a winch, Other than the pto shaft what else would I need to make this work?
57 Allis Chalmers D14
59 Allis Chalmers D14
Mustang 940 skidsteer
JD350B dozer
tjdub
Re: 3315 Winch value?
Post by tjdub » Mon Jan 17, 2011 10:05 am
dustin502 wrote:I came across a guy with a 3315 winch and I need some advice on a fair value. The guy said the winch has been sitting in the weeds close to 15 years so I'm sure it is in poor condition. My 350B isnt set up for a winch, Other than the pto shaft what else would I need to make this work?
Does the winch still have a round control valve attached to the back of it? If not, you are probably going to have a problem finding one. Deere does not have replacements.
Other than the valve, there's just the control cable and lever. Deere doesn't have the lever kits anymore either so you'll have to make your own. On my 450, I rigged up a salvaged hydraulic control lever and bought a control cable from http://www.midwestcontrol.com. The lever's mount and cable holddown are just bolted right into the back of the battery box. This works nice because it's easy to run the lever from the seat or when standing next to the winch.
dustin502
Post by dustin502 » Mon Jan 17, 2011 10:59 am
I didnt see a valve on the back of it, It has 4 Hydraulic lines going into the housing by the hyd filter. I guess the hydraulic lines would hook to the control valve? Any idea what a fair price would be?
JD350B dozer
tjdub
Post by tjdub » Mon Jan 17, 2011 11:30 am
dustin502 wrote:I didnt see a valve on the back of it, It has 4 Hydraulic lines going into the housing by the hyd filter. I guess the hydraulic lines would hook to the control valve? Any idea what a fair price would be?
If there are lines coming out, then it probably has a spool valve instead of the rotary valve. The rotary valve didn't use any lines, it just bolted right into the winch. Are the lines just unhooked, or do they go to a spool valved bolted on below the filter? Here's the spool valve setup:
The spool valve is not available from Deere anymore either, but you should be able to find something that would work. I didn't know they used the spool valve on 350s though. Are you sure it's a 3315 and not a 3325 off of a 450?
As for the price, I'm not sure. I've seen complete units in working condition advertised for $1500, and AS-IS-IN-THE-WEEDS ones advertised for $500. Those were asking prices though.
dustin502
Post by dustin502 » Mon Jan 17, 2011 11:41 am
Looking at the side of the winch were the hyd filter is, there is one hose on the left of the filter and 3 on the right side3 of the filter. There is no valve there. The winch has a tag on it that has 3315 and a serial # on it.
JD350B dozer
tjdub
Post by tjdub » Mon Jan 17, 2011 12:15 pm
Well, having no control valve is kind of a hang-up, unless you can find a used one.
This place is making aftermarket valves.
http://www.foxprintskitstore.com/servle ... -JD/Detail
At $800 for just the valve, you're probably better off finding a a winch with a valve on it.
dustin502
Post by dustin502 » Mon Jan 17, 2011 12:19 pm
That is alot of money for the valve! I've made a few phone calls to a salvage yard. I havent heard anything back yet.
JD350B dozer
tjdub
Post by tjdub » Mon Jan 17, 2011 12:58 pm
dustin502 wrote:That is alot of money for the valve! I've made a few phone calls to a salvage yard. I havent heard anything back yet.
Yeah, it's definitely a specialty item. The seller of the winch may have already got his money out of the winch by selling that valve off of it :)
In theory, you could rig up two independent off-the-shelf spool valves. One locking log-splitter-type valve to control the brake cylinder and one normal valve to run the clutch. Depends on how much you like cobbling things. :)
dustin502
Post by dustin502 » Mon Jan 17, 2011 7:12 pm
I may end up trying to rig something up. I would much rather find the correct parts for it. I'm going to try work out a deal with the guy in the next few days and keep looking for other parts as well. Some machines have a pto disconnect lever, does anyone know if that is required when using a winch?
JD350B dozer
tjdub
Post by tjdub » Mon Jan 17, 2011 8:54 pm
dustin502 wrote:Some machines have a pto disconnect lever, does anyone know if that is required when using a winch?
No, it's not required. Deere just up and decided that it wasn't necessary.
See http://www.jdcrawlers.com/messageboard/ ... php?t=5621
dustin502
Post by dustin502 » Tue Jan 18, 2011 11:40 pm
tjdub, Thanks You've been a big help. I'm going to keep looking and checking with some salvage yards to see what I can come up with.
JD350B dozer
tjdub
Post by tjdub » Wed Jan 19, 2011 9:18 am
No problem.
There's one on craigslist in TN here: http://boone.craigslist.org/grd/2138626389.html
I hope I'm not leading you astray on adding the PTO shaft. I don't have any real experience with 350s, but I assume it's just a kit that can be added to any 350B. I've been wrong plenty of times though. Maybe someone with a 350B can comment. Ideally, you could find a powershaft and the winch for sale together as a package. I know I've seen them for sale together before.
dustin502
Post by dustin502 » Wed Jan 19, 2011 2:57 pm
I just called the guy in TN and he dosent have the control valve or anything else to go with the winch. I'm going to find out tonight what the guy wants for the winch here, He has a complete diesel engine i'm going to try to get as well. I dont need it but, I might need it in the future.
JD350B dozer
dustin502
Post by dustin502 » Thu Feb 03, 2011 12:29 pm
Well here is the winch fresh out of the weeds. I know it is rough but, on a plus side I got a log arch with it. Can anyone tell by the pictures witch control valve it would take? Anybody have a control valve that they would part with? Also looking for the winch pto drive shaft. As always any advice or opinions would be appreciated.Image
JD350B dozer
tjdub
Post by tjdub » Thu Feb 03, 2011 3:23 pm
Nice logging arch! I've been looking for one for my 450 for a long time, but they're pretty hard to come by.
That's definitely set up for a spool control valve (not the rotary one). In order to make a rotary valve fit, you would need to re-route the lines since they all need to come out of the housing right by the filter in a tight pattern.
As for the lines coming out there, the one all by itself on the left of the photo is the pressure line coming from the hydraulic pump, the two on the right are for the activating the clutch and deactivating the brake. If you pull that side cover off, you'll see which is which. The return line back to the reservoir is the one coming out of the oil filter mount.
Both the clutch and brake lines require 1000psi to activate. In Freespool mode, the brake line should be at 1000psi. In Wind mode, both the brake line and the clutch line should be at 1000psi. In brake mode, nothing is activated. Sounds simple doesn't it? Too bad there's just not a lot of call for a valve that does that. :)
You could talk to someone who knows hydraulics to see if you could rig up two of these together:
http://www.northerntool.com/shop/tools/product_472_472
If you could just set the first valve to 1000psi and set the detent release pressure a lot higher then when it's in detent, have it supplying 1000psi to the brake line and a second identical valve. The second valve would be hooked to the clutch line and also be set to 1000psi but the detent release pressure turned very low or off because you won't want to lock your clutch ON. It seems like it would work. Either that or it will explode, I'm not sure :D
Users browsing this forum: No registered users and 253 guests
