jd440ic distributor timing
dtoots1
Post by dtoots1 » Fri Jun 26, 2020 9:00 am
well folks..am having a question on my timing...it seems that my points are opening just after it goes past the wire. i have not moved the distributor since i bought it and has been running ok, points gap is at 22 thousandths and is open about 3/4 inch past the wire on the outside circumference of distributor.....i assume that i should turn the distributor to that area and see if it helps tho with my hearing am not sure of results. i assume the points would then open at the wire as i believe it is supposed to. do not have timing light.
Re: jd440ic distributor timing
Post by Lavoy » Fri Jun 26, 2020 9:12 am
Set the flywheel to spark, rotate the dist til the points just start to open.
dtoots1
Post by dtoots1 » Fri Jun 26, 2020 11:11 am
Thanks Lavoy,
must have been real close as only had to move it a hair.
seems to be o.k. now...
will see later how she does
Users browsing this forum: No registered users and 173 guests
