JOHN DEER 350 3 CYL DIESEL
Bobcaterdon
Post by Bobcaterdon » Mon Mar 30, 2015 2:47 pm
ON MY 350 3 CYLINDER DIESEL I HAVE PORED TO MUCH DIESEL DOWN THE EXHAUST; WILL IT FIRE WITH THE EXTA DIESELL IN THE CYLINDERS
A MATURE MECHANIC DON
Bobcaterdon with JD420C 1956 S/N80779 &&&
MF 711 skid steer
Post by jtrichard » Mon Mar 30, 2015 3:31 pm
HOW much is to much? if its way to much you could hydraulic a cylinder and possibly bend a rod .... just to much it could run ape shit for a short time (hope nothing comes out the side of the block)...just a little to much and it will smoke like crazy for a short time ... let it set a day or two and the diesel should make its way past the rings and you should be good :idea: :idea:
gregjo1948
Post by gregjo1948 » Tue Mar 31, 2015 5:40 am
It will probably react as it would with too much starting fluid. Things could bend or break.How hard would it be to pop out the injectors and crank it over to push out the excess diesel? gregjo1948
Post by Stan Disbrow » Tue Mar 31, 2015 8:54 am
Not much space between the top of the piston and the head on a diesel. I would pull the injectors and manually crank it over rather than risk a hydraulic lockup and bending rods....
shinnery
Post by shinnery » Tue Mar 31, 2015 11:16 pm
Which is easier to pull, glo-plugs or injectors? I believe either would prevent hydro-lock and bent parts.
Post by jtrichard » Wed Apr 01, 2015 12:21 am
I dont believe treefity has glow plugs
Post by Stan Disbrow » Wed Apr 01, 2015 6:28 am
No, the JD 3-cyl series do not have glow plugs. But, yes, if they did pulling the GPs would be a lot easier. :)
gregjo1948
Post by gregjo1948 » Wed Apr 01, 2015 6:46 am
I think it could be turned over manually, stopping if there is too much resistance. If it turns completely over, I'd just bump the starter until it made a couple revs and then go for starting it. gregjo1948
Users browsing this forum: No registered users and 260 guests
