brucek
- 40C crawler
Post
by brucek » Mon Mar 30, 2015 4:21 am
I have my 350 straight crawler loader in the shop changing the rear cross bar so now is the time to fix anything and everything. I have noticed a lot of hydraulic oil coming from the top of the hydraulic tank. It appears to be coming out of what I think is a pressure relive valve mounted to the top of the tank. Any ideas what would be causing this? I also need 2 new hood latch pins if anyone has some for sale?
Jd450/6-way
- 420 crawler
Post
by Jd450/6-way » Mon Mar 30, 2015 11:16 am
is your shop heated? where about's are you located. We have had guys at work fill the equipment full of fuel outside in the -20 and bring then into a heated shop and leak fuel out the filler caps.
brucek
- 40C crawler
Post
by brucek » Mon Mar 30, 2015 2:14 pm
The shop is heated but I noticed the oil before we brought it in. It seams to spit fluid out the relief every time I use the bucket. Any direction. I kind of was hoping somebody was gonna say this is a sign of a dirty hydraulic filter in the tank. I haven't pulled the top plate off yet to inspect.
Scottyb
Post
by Scottyb » Mon Mar 30, 2015 7:38 pm
I will say it....sounds like a dirty filter.
backhoe attachment.
