1010 fuel primer assembly
millwrightcrawler7114
Post by millwrightcrawler7114 » Thu Mar 26, 2015 2:46 pm
I have just recently purchased a JD 1010 and it does not have the dash mounted fuel primer. I would like to add that feature. Any help with that in the way of parts and/or advice would be greatly appreciated.
Post by Tigerhaze » Thu Mar 26, 2015 4:03 pm
Welcome to the board.
We have had a number of discussions about aftermarket priming solutions for the 2010 diesel crawlers; the 1010 diesels should be very similar.
This is a thread that captures most of the discussions if you look at the hyperlinks referenced:
http://www.jdcrawlers.com/messageboard/ ... ght=primer
fuel primer
Post by millwrightcrawler7114 » Fri Mar 27, 2015 3:52 pm
Thanks for the input. The members of JDcrawlers always have great information. My search will continue, no doubt I will find what I need. :)
Post by jtrichard » Fri Mar 27, 2015 4:51 pm
here is one like i used i dont remember what i had to use in the way of fittings http://www.ebay.com/itm/VINTAGE-CESSNA- ... 92&vxp=mtr made by same company as OEM just different fittings
pop pop
Post by pop pop » Sat Mar 28, 2015 6:00 pm
your not talking about the dash button that gives(actuates a solenoid on an ether setup) a shot of ether, are you?
Post by Lavoy » Sun Mar 29, 2015 9:21 am
No, a fuel primer, it injects raw fuel into the intake manifold for cold weather starts.
Pretty sure I got mine from Aircraft Spruce, still get e-mails from them from time to time. It won't be like OEM, much smaller and cheaper, but works fine.
Post by jtrichard » Sun Mar 29, 2015 11:01 am
Users browsing this forum: No registered users and 149 guests
