Is there anything out of the ordinary when installing injectors?
make sure eal is on injector
put in hole
put shims below hold down
Install hold down bolt
Re attach fuel lines?
Just want to make sure I am not missing any important parts...
How to on injector install
Im Addicted to John Deere's
1957 JD 420c 4 roller w/ reverser
196? JD Straight 350 Diesel 6 way blade
1945 JD B
1940 JD H
1951 JD GW
1955 JD 70D
1957 JD 720D
1959 JD 730D
1945 JD B
1940 JD H
1951 JD GW
1955 JD 70D
1957 JD 720D
1959 JD 730D
I usually put anti-seize on the injector prior to installation.
Users browsing this forum: Google [Bot] and 20 guests
