John Deere 440IC crankshaft
lawsp0ma
Post by lawsp0ma » Wed Mar 25, 2015 3:15 pm
I am needing a crankshaft for a 440IC gas track loader. My crank is a M3114T. Will other cranks from say an MT fit? I see other info that says this is the same motor as this or that but would like to clarify the difference or should I be looking for only this P/N. If someone has one for sale I would be interested. I also need the seal cap for the big end of the crank as well as a starter ring gear. Thank you in advance for the help. I know I have found the right place to get some answers. I know I will have more.
Post by Lavoy » Wed Mar 25, 2015 3:22 pm
Other than two cylinders, not the same engine as M.
I should have a crank on hand, ring gear is no problem not sure about rear seal holder, would have to dig.
Welcome to the board.
