Wear Strip on 350B Front Idler track frame
cjman1977
Post by cjman1977 » Sat Jan 17, 2015 3:04 pm
Does anyone know the dimensions of the WELD ON wear strip on the under side of the C channel track frame where the front idler slides? Also, is it AR plate or a medium to high carbon steel?
Mine is so thin it only has one side. :lol:
Bennett
JD 350B w/ 4 in1
JD 4520 Compact Utility
JD 1025R Sub Compact
Cat 303.5 Mini Ex with Bushmaster Brush Cutter
Soilmover Dirt Pan
Toofarnorth
Wear strip
Post by Toofarnorth » Mon May 11, 2015 12:31 pm
I would like to know this as well...
Edit:
So after no guidance on this I sheared out some strips of ar400. I hope I went the right direction with that...
