2010 sprockets
danny
2010 sprockets
Post by danny » Wed Dec 10, 2014 5:36 pm
Hello
There is a brand new / old set of 2010 sprockets for sale nearby. The picture shows the hub bolt pattern and it appears the same as my 420....6 holes for bolts and 3 stud holes.
Did 2010 have the same pitch track as the 420 and would the bushing OD be the same as the 420 or a 350??
thanking everyone that responds. I want a good track system
Post by Lavoy » Wed Dec 10, 2014 5:56 pm
It could be either bushing size, but if you are looking at them for a 420, not even remotely close to working.
danny
Post by danny » Wed Dec 10, 2014 6:05 pm
Thanks Lavoy
Is the ctr to ctr of the pins on a 2010 the same as the 420 / 350....5.75" ?
I realize that the sprocket offset probably is different but I can machine out the center and weld in another.
thanks again
Post by Lavoy » Wed Dec 10, 2014 6:40 pm
They will not fit, no amount of machining will work, they are larger in diameter, and different in offset.
Post by Tigerhaze » Thu Dec 11, 2014 5:02 pm
Hi Danny-
If not useful for you, can you provide the contact information on the 2010 sprockets and whether they are early or late part number?
Users browsing this forum: No registered users and 68 guests
