350 steering clutchs
rivercabin53
Post by rivercabin53 » Tue Nov 11, 2014 1:36 pm
Thanks for the help so far.
I now have the final drive off my 350 and need to know how to check the disc for the steering clutches ? I have taken off the pressure plate but don't know the specs for the plates. And what should they look like the ones I have a center and about 1/16 on each side and looks like were groves about half way down. Thanks Larry
dillon45
Post by dillon45 » Sat Nov 15, 2014 11:41 pm
There is a site, I think it tractornet but not sure. anyway this guy
shows the process from start to finish on a 350 JD, lots of pictures with
commentary. I do remember it was very important to have the clutch pack
in spec . It may help you a lot, and the folks there were very helpful in
walking the guy through it. Hope this helps and good luck.
PS It may have been a 450 JD but I think it don't really matter.
dillon45
Post by dillon45 » Sun Nov 16, 2014 12:18 am
JD 350Bw Dozer - advise needed please
www.tractorbynet.com/.../199695-jd-350b ... eeded.html
The dozer is a John Deere 350Bw (wide track with blade extentions), ... I've bought a 350B loader and had to replace both steering clutches.
Recommeded hydraulic fluid for my 350 John deere dozer
www.tractorbynet.com/.../280030-recomme ... d-my-350-a. html
The system has drained out so all of the fluid will have to be replace. No problem ... A John Deere 350B has dry steering clutches. It uses JD ...
1010 / 1020 Differences - Page 2 - TractorByNet.com
www.tractorbynet.com/.../john-deere.../ ... ces-2.html
i know this is an old post but did the 2010 have wet steering clutches..i know i got a 1010 and ... tracks are worn out so i understand that ..but i've replaced seal upon ... have the same clutches as say a 350 b...now that was a good dozer ... just a mess ...the 350 jd has more a set of clutches in there that work ...
Buying Advice 1973 JD450B Dozer
www.tractorbynet.com/forums/.../229282- ... dozer.html
Basically, you need to replace the steering clutches and brake bands on it. ... Go to JDCrawlers.com - The Enthusiasts Site for John Deere Crawlers for more information. ... Cat D3, Deere 110 TLB, Kubota BX23 and L3800 Craftsman Mower, Deere 350C Dozer ... If you don't by that B let me know, I will.
Dozer,pedal steer or lever steer?
www.tractorbynet.com/.../93877-dozer-pe ... steer.html
I have a Allis Chalmers HD4 which has lever steer. ... John Deere and Case no longer make the 350's. and I didnt like them when they did.
www.tractorbynet.com/.../john-deere.../ ... ences.html
The John Deere 1010 and 2010 tractors were 4-cylinder models that ... He replaced the 2020 with its great-grandson, the 2355. .... i know this is an old post but did the 2010 have wet steering clutches..i know i got a 1010 and it will ... if they have the same clutches as say a 350 b...now that was a good dozer ...
Oil & Fuel JD 350c crawler-dozer clutch-tran-fluids questions
www.tractorbynet.com/.../john-deere.../ ... zer-clutch .html
1. my unit has a reverser so no dry clutch for tranny. therefore it is all a ... spring is easy to replace and had floor plates off but now, from previous forum topics, ... I am not experienced with a JD 350 dozer, but milky fluid indicates water in the oil. .... Kioti Tractors · Mahindra Tractors · Bobcat Skid-Steer · More ...
Small Dozer Questions (Komatsu/Mitsubishi)
www.tractorbynet.com/.../104461-small-d ... mitsubishi. html
I'm a big dozer guy, but I learned on a John Deere 450G that is around 70 hp. ... The Case 350 does not have steering clutches only a steering brake, which ... Id probably take the standard shift as it would be easier to repair ...
Performance of CTL vs true Crawler Loader?
www.tractorbynet.com/.../216908-perform ... awler.html
Something along the lines of a 350B-355D John Deere crawler loader .... a neat, old piece of equipment I paid 5K for and it needed steering clutches. ... small tree removal, without so much movement as with a crawler loader.
International 500c crawler/Dozer
www.tractorbynet.com/.../127101-interna ... dozer.html
Is there a chance the steering clutch could be stuck or slipping? ... it down, clean, inspect, repair and replace to get the steering clutch(es) working right. ... I got an old JD350B late last spring and spent $1100.00 to get new brakes, steering .... Kubota Tractors · John Deere Tractors · New Holland Tractors ...
12345678910
