820 loader
- vailvalley59
- 430 crawler
820 loader
Does anyone have a Wix number for the filter on an 820 loader for a 2010? Thanks
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
- vailvalley59
- 430 crawler
loader filter
Thank you I do not have a book for the loader--would you have the JD number of this filter and do you think it would fit all the loaders on 2010s? I have not pulled the old one--it might have a number on it--I was trying to get the new one first. thanks
JD # U 12610 U filter ...gasket (JD calls it a seal) #U 12603 U .....also need o rings 1 each # U 12037 U and U 10778 U and R 460 R ... here is parts book http://jdpc.deere.com/jdpc/pdfs/PC0705.pdf page 12
FYI, there are actually two "filters" within the loader hydraulic reservoir- a large inlet element and a smaller outlet element. The small outlet element one mounts to the large inlet element. JT listed the large inlet element; the outlet element is AU 11215 U. The O-rings JT listed are actually for the outlet element.
Oftentimes the outlet element can be reused but you should inspect, and I am not sure the availability of it as when I bought it was many moons ago.
Also when you buy the parts you will need to take the elements apart from the filter "handle" (the u-shaped base that mounts to the reservoir). They are NLA from Deere and when I busted mine I had to search parts yards to get another one.
HI Tiger i did not want to confuse the issue with the smaller filter as it is a steel mesh screen and should NOT be a problem (should just need a good cleaning) and the are very expensive if they are even available any longer..... i would replace all the o-rings while i was in there (since you have to take the whole thing apart any way)... Do i dare ask how in the (H e double hockey sticks) did you ever break the filter "handle"?
I agree the outlet element usually can be reused; in my case the reservoir had a lot of water in it and the outlet element corroded so I went ahead an replaced it. However your point is well taken that it is not a micronic filter like the large inlet filter.
As for breaking the filter handle, it is pretty embarrassing but I was sawing one of the large hardwood trees at my property and had the crawler parked a little too close to the fall zone; one of the large branches hit the handle and cracked it at the base to where it wouldn't seal under pressure so had to find a new one
Users browsing this forum: Google [Bot] and 389 guests
