350 b track adjuster spring broken
D Watson
Post by D Watson » Wed Nov 05, 2014 8:12 pm
350 b doizer need to replace track adjusters and springs need
advise on how to remove tracks and relieve tension on springs
sullyt28
Post by sullyt28 » Sun Nov 09, 2014 8:33 am
Next to the grease fitting on the adjuster should be a bolt to release pressure. I used a block between the blade and front idler to push the front idler back. Next you want to find the track pin and position it 11:00 on rear sprocket and drive the pin out to break the track. The rest should be fairly straight forward.
Sully
Barrie, ON
shinnery
Post by shinnery » Sun Nov 09, 2014 8:40 pm
There should be a ball bearing under that bolt that you have to loosen to let grease out of the cylinder. Be sure you do not loose it when removing grease from the adjuster cylinder, if you loose it you will have a hard time sealing the cylinder to tension the chain.
Post by jtrichard » Sun Nov 09, 2014 10:51 pm
You do NOT remove the bolt completely just loosen it a few turns.....if you lose the ball you wont keep ANY grease in the adjuster
jsal
loosening tracks
Post by jsal » Mon Nov 10, 2014 6:01 am
an easy way to loosen a track is to place a piece of wood on the sprocket and rotate also just remove the grease fitting to let the grease out
JIM
