450e clutch adjustment
IWLBCNU
Post by IWLBCNU » Wed Nov 05, 2014 3:16 pm
Have a 1986 450E, had it a few years, low usage, clutch stops fine but the range shifter grinds and have to cut it off to change. Is the procedure online?
Post by Stan Disbrow » Wed Nov 05, 2014 5:00 pm
There is no engine clutch. The thing which acts as a clutch pedal operates a hydraulic valve. There is (or was) a shaft brake in there to stop the shaft. They wear out and then you have your grinding issue.....
Post by Stan Disbrow » Thu Nov 20, 2014 3:44 pm
I disagree with me, too. For some reason, I was thinking 350, not 450. In my defense, it must have been all the 350 isolator discussion as of late.
Sorry. I never had a 450, so usually stay out of 450 discussions.
IWLBCNU
Post by IWLBCNU » Tue Nov 25, 2014 9:19 am
Thanks, I just came here to post that jdparts showed it having a regular clutch.
1957 420C Orchard w/ only 800 hrs
1986 450E ex VA Forestry
Post by Stan Disbrow » Tue Nov 25, 2014 11:17 am
Of course it does. Pay no attention to me. I apparently don't know a 3 from a 4 these days......
It is, of course the *3* 50 with a reverser which has no clutch......
