350 isolator spring postion
butchb
Post by butchb » Sun Nov 02, 2014 5:28 am
replacing isolator on straight 350 all new parts from deere, need to know spring postion on isolator book not very clear?
1967 jd 350
cantbeatadeere
Post by cantbeatadeere » Sun Nov 02, 2014 5:08 pm
The hardware that bolts to the flywheel -- the open part of the spring faces to your right as your facing the flywheel. The engine rotates COUNTERCLOCKWISE and the sleeve that bolts to the flywheel should push towards the solid side of the spring hook not the open side...hope this helps. BTW clean and loctite the threads on everything!
butchb
thanks for the help
Post by butchb » Tue Nov 04, 2014 4:46 am
thanks for the reply
1967 jd 350
