pad bolts
JayinPA
pad bolts
Post by JayinPA » Sat Nov 01, 2014 6:26 pm
What size and length of bolts for the track pads on a440 dozer? I did't take any out yet but they look to be about 1/2×13/4long.
Post by Lavoy » Sun Nov 02, 2014 1:37 pm
Should be 5/8" assuming still 2 bolt pads
JayinPA
Post by JayinPA » Sun Nov 02, 2014 3:06 pm
Thanks Lavoy they are still 2 bolt pads. I have a few loose pads and need to replace the bolts.
gregjo1948
Post by gregjo1948 » Mon Nov 03, 2014 5:25 am
What does 13\4 mean? gregjo1948
Post by jtrichard » Mon Nov 03, 2014 10:44 am
1- 3/4"
gregjo1948
Post by gregjo1948 » Tue Nov 04, 2014 7:37 am
jtrichard wrote:1- 3/4"
Do I get a prize for dumbest question? gregjo1948
Post by Stan Disbrow » Tue Nov 04, 2014 7:50 am
No, not really. I had the same 'Huh?' moment myself. I almost asked about it myself, but then I figured it out:
Thirteen Quarters? What an odd way to say it. That would be Three and a Quarter. Way too long. Those bolts are more like Two Inches. Oh. Wait a second. Missing Space Error! One and Three Quarters. Yeah. That is more like it! ;)
JayinPA
Post by JayinPA » Tue Nov 04, 2014 1:24 pm
I see I missed the space in 1 3/4 . I found some bolts today.They are grade 5 instead of grade 8 but I think they will do.I have 7 pads that are loose.I guess it's time to get out the air wrench and torch.I need to get ready to drag some more firewood out.
Post by Paul Buhler » Fri Nov 07, 2014 9:47 am
Hi: The grade 5 bolts will stretch more over time and loosen. Dedicated pad bolts usually have a taller head, fine thread and are harder to withstand torqueing/tightening without lock washers, and the rigors of their job. If you use your machine lightly in soft soils, it's worth a shot to go with what you've got. Pad bolts are pricey. JMHO. Good luck. Paul
Post by Lavoy » Fri Nov 07, 2014 11:29 am
What I have done for years is grade 5, fine thread bolt, no lockwasher, standard nut. Torque until a good half inch impact stalls and quit. In more crawlers than I can remember, I bet I haven't retor questions 20 bolts.
A fine thread bolt exerts more pressure, the grade 5 bolts might stretch a little so they are under some tension, and you don't waste any torque by using standard nuts, and they re-torque easier if you ever need to.
lavoy
Post by Paul Buhler » Fri Nov 07, 2014 12:55 pm
I'll defer to Lavoy's thoughts; he's done this a lot more than I have. Paul
Post by Lavoy » Fri Nov 07, 2014 8:23 pm
I agree true pad bolts are definitely stronger, no question. But spendy, so not worth the money to me, but sure won'the hurt anything to use them. I have seen them on tracks with short grousers and they can stick up above the grouser.
Factory deere bolts are only grade 5 for the two cylinder crawlers. The domed head pad bolts are a later invention, and anything more modern using a 5/8" pad bolt will have 4 of them, and probaby well up in the 150 horse range.
lavoy
