Changing out drive sprockets
scremineagle
Post by scremineagle » Sun Oct 26, 2014 6:37 am
Just got my new drive sprockets for 1966 350 straight and was wondering if u guys would suggest any other maintanence while changing out sprockets. Thanks
wizner85
Post by wizner85 » Mon Oct 27, 2014 6:39 am
I'd check to see if the bearings in the final are good. I usually see if there is an excessive play in the shaft etc.
Change out the gear oil in the finals since you have it half apart.
I usually power wash everything before I work on it as well. That will help you see any loose bolts, or see if anything is broken.
Good luck.
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
Users browsing this forum: No registered users and 34 guests
