40C cluthch problem
fundytides
40C cluthch problem
Post by fundytides » Wed Oct 22, 2014 11:48 am
I rebuilt the motor in my 40C a year or so ago and installed a rebuilt clutch assembly at that time. I haven't been able to get the correct adjustment on the clutch pedal. With full adjustment, I still have about 3" free travel in the pedal and have to depress the pedal well below the footrest to get any disengagement and even then the clutch dosen't seem to fully disengage. Could I have assembled something wrong or overlooked something when installing the clutch or throwout bearing and sleeve?
wizner85
Post by wizner85 » Wed Oct 22, 2014 12:36 pm
Did you adjust the pressure plate fingers using the JD gauge before reinstall?
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
fundytides
Post by fundytides » Wed Oct 22, 2014 2:09 pm
No I didn't. I later installed steering clutches and used the gauge then but wasn't aware that it was something that needed to be done with the regular clutch. I assumed that the rebuilt unit would be set properly. Guess I was wrong?
wizner85
Post by wizner85 » Wed Oct 22, 2014 6:01 pm
Have to do the same thing on the main clutch as you did on steering. You use the same gauge just the part that sticks out the farthest for finger measurement.
Sorry for the bad news, but engine needs to come out to be fixed properly.
420 62 blade 3pt
fundytides
Post by fundytides » Wed Oct 22, 2014 8:07 pm
That's what I was afraid of. I'll have to chase down the tool. I gave it to a guy who was working on his steering clutches who passed it on to another guy. Oh well, that's the fun of old vehicles and equipment. Thanks for the help
gregjo1948
Post by gregjo1948 » Sat Oct 25, 2014 5:57 am
Will the gauge for 1010 work on any other machines? Thanks, gregjo1948
