Track tensioner 420C
I replaced the bolts on my 420 with a grade8 bolt I purchased from BigBolt.com . They worked well at first but after a couple trips through the barn yard they have became very rusted just like the ones I took out and very hard to move. Is there any good fix to this problem? Is there a cylinder type tensioner made for a 420C?
Track Tensioner 420C
Non plated bolt with a cadium plated nuts. I am thinking about making some Brass nuts twice as long as a normal one. Also I talked to an old guy
that still runs a dozer for a living at 82 yrs and he said when you put them on clean and free of dirt they used to run candle wax on them.
Big Bolt??
What is the correct Big Bolt web site? Sounds like an interesting site to have in reserve.
CPeter
CPeter
40C, 420U, Dubuques for 35 years
track tensioner 420C
The Web address for Big bolt is http://www.bigbolt.net/
I don't know how to do that fancy stuff where you just click on it.
No, I haven't yet. I probably will try something in the future, I may have been tightening against the spring because I pulled it out last night after completing ring and pinion rebuild and I noticed both tracks were so tight one could have probably played the musical note of "G" on them there both the same I will need to loosen them before I use it. There might not be a problem after all. Dozer operates good after rear end rebuild. Battery charging right now might get some time to play this weekend
420 track tensioner
I used grade 8 I ordered extra threads (14" I think). Cost was about $35.00 ea
420C track tensioner
They custom made the bolts I bought. They will plate for a fee. They also roll threads as well as cut threads about anything oe would desire
Users browsing this forum: Majestic-12 [Bot] and 12 guests
