JD straight 450 input shaft
Hello! Thank you for taking the time to read this. My
Dads JD straight 450 had the HLR input shaft shear in
half. The problem I am having is the Parts Catalog states
it is an AT21511, but it is different than shown. On the
front of the shaft it has a spline and a snap ring and a
keyway on the back of the shaft...but all of the shafts I
have found have a keyway on both ends....If anyone has
dealt with this before or knows where I can locate a
serviceable one help would be appreciated.....Thank you.
That looks just like the one in my 450 also. Can't help with locating parts but I would suggest figuring out why it broke. Are your bellhousing spacers broken? Did the engine mounting bolts break or work loose? Something put a lot of stress on the shaft. Good luck
Machinist by trade, farmer by blood.
Users browsing this forum: Google [Bot], NevadaKid and 192 guests
