Hard starting 650 H
Robin Hood
Hard starting 650 H
Post by Robin Hood » Tue Sep 30, 2014 3:26 am
Would appreciate your thoughts on this problem. We have a 2001 model 650 H dozer that has developed a bad habit of starting hard. It never started hard in the coldest of weather before this spring. You have to crank it for quite a while (30 seconds) before it will light off. Seems as though the fuel leaks down after it sits for a while. We have replaced the fuel filters and the lift pump. There are no obvious leaks anywhere. I was wondering if there are any check valves that could be leaking.
Post by Tigerhaze » Tue Sep 30, 2014 2:36 pm
Maybe glow plugs are bad? I would assume it has them and maybe they burned out over time?
ja600
Post by ja600 » Tue Sep 30, 2014 6:12 pm
Does it blow white smoke after starting? Injectors maybe bad. Sounds like a fuel issue in any case.
Machinist by trade, farmer by blood.
Users browsing this forum: No registered users and 289 guests
