1967 1010 need parts
jblair34
Post by jblair34 » Fri Sep 19, 2014 1:06 am
I got a 1967 john deere 1010 dozer with a 4 way blade and got a little bit of work to do on it. First thing was i needed a new hydro pump so i put another vickers pump on it the other one is shot it wasn't the oringal but what every works right. Second thing is to get new clutches, throw out bearings pressure plates, springs whole nine yards for both final drive sides and brake band for one side ( if anyone knows where to get this stuff please let me know Thanks). Last thing is, in the gear box that has the input shaft that has 1st 2nd speed cluster on it i need both end cone bearings the bearings, spacer, snap ring, and the thrust washer that the gear cluster rides on on the input shaft. Dozer only has 1 gear which is forth gear to move forward and back as of now so cant really do any work with it plus its tore all apart in my garage now. needing parts and buying asap when i can find them. does anyone know where to find the serial number located on this dozer thanks. will post pic of machine when i can figure out how to. Thanks for all your help
vtjoe
your parts
Post by vtjoe » Fri Sep 19, 2014 6:16 am
Lavoy.... probably has all the parts you need. he runs this site
DukeofDeere
Post by DukeofDeere » Fri Sep 19, 2014 10:43 am
If the tag is there it is on the right side on the engine block.
Duke
Post by Lavoy » Fri Sep 19, 2014 12:49 pm
Should have most of the parts on hand.
jblair34
Post by jblair34 » Sat Sep 20, 2014 9:06 pm
Awesome, will get with you lavoy to see what we can do about me getting the parts i need. Do you have an email. Thanks everybody with your responses.
jblair34
Post by jblair34 » Sat Sep 20, 2014 9:35 pm
Can you post pic to the message board.[/img]
Post by Lavoy » Sun Sep 21, 2014 11:21 am
E-mail is at the bottom of any of my posts. Yes, you can post pics, but must be hosted at picture posting site and link to it here.
jblair34
Post by jblair34 » Mon Sep 22, 2014 5:52 am
Thanks lavoy will be faxing list of parts that i need with pages of the 1010 manual so u know what i need thanks.
1967 1010 crawler
gregjo1948
Post by gregjo1948 » Wed Sep 24, 2014 5:19 am
I thought 1010 dozers ended in 1965. gregjo1948
jblair34
1967
Post by jblair34 » Wed Sep 24, 2014 5:38 am
When I bought it this is what the guy told me not for sure if this is the case. Trying to locate engine name plate but no luck.
1967 1010 crawler
Post by Stan Disbrow » Wed Sep 24, 2014 6:44 am
Yes, the last year of 1010 production was 65. It was replaced by the 1020 on the wheel tractor side, which was a completely different machine using a 3 cylinder engine.
There was no 1020 crawler, that spot being taken over by the JD 350, with the 3 cylinder engine like in the 1520 wheel tractor.
jblair34
Post by jblair34 » Wed Sep 24, 2014 1:19 pm
awesome thanks for setting me straight. Will look for some numbers on engine to try and see what i can come up with thanks a lot. Josh
1967 1010 crawler
Post by jtrichard » Wed Sep 24, 2014 2:37 pm
if you get some pics and info of what you have we can narrow it down as to the approx. year...... is it gas or diesel? does it have a reverser? if yes where is the lever? spin on oil filter?
jblair34
1967 dozer
Post by jblair34 » Wed Sep 24, 2014 3:02 pm
Yes it has a reverser located on dash board left side four speed, four cylinder gas engine. yes screw on oil filter located if you are sitting on the dozer right side in front of the distributor. I found a number in the casting on the left side of dozer engine close to the front (15879T) don't know if this is a part number for crank case or what, cant find a nomenclature plate on right side of engine where it is suppose to be located. everything looks to be original so must have just fail off at some point in time. will post pic to my facebook if you want to take a look. Joshua Blair and i have a pic on my cover photo of me my son and daughter. Thanks
1967 1010 crawler
Post by jtrichard » Wed Sep 24, 2014 5:59 pm
if it has a spin on oil filter and has a paper air filter then it is post 42000 built in or after late 1963.... the trans range shifter (not the reverser) is on the floor not in the dash? only the very early ones where in the dash like 1961
