MC undercarriage swap
MountainHighMC
Post by MountainHighMC » Sun Sep 07, 2014 8:48 pm
Hey guy's I've got a working MC, and a 4 roller 40 for parts.
The 40 has a Gearmatic twin cylinder angle dozer on it that I would prefer vs the inside mount straight blade on the MC. Also the three roller is quite the rocking horse, I figure the four roller would be more desirable.
Any suggestions on doing the swap or not would be greatly appreciated.
Thanks Bradley
gregjo1948
Post by gregjo1948 » Mon Sep 08, 2014 4:26 am
Which way are you going to do the swap? It might be easier to use the MC parts on the 40. gregjo 1948
Post by Lavoy » Mon Sep 08, 2014 9:07 am
Will work fine, you will need to use the complete undercarriage from the 40 including tracks, excluding sprockets.
MountainHighMC
Post by MountainHighMC » Mon Sep 15, 2014 12:11 pm
Thanks for the replies boy's
I was hoping to use the four roller under the MC
Hey Lavoy, the sprockets are the same then?
I was thinking that I should be able to remove the tracks, crossbar clamps and hydraulic paraphernalia.
Pretty straight forward I figure.
Post by Lavoy » Mon Sep 15, 2014 3:54 pm
Correct, sprockets are the same.
Users browsing this forum: No registered users and 155 guests
