450B STEERING CLUTCH / METALLIC VS FIBER PLATES
JUST TORE DOWN MY 450B FOR STEERING CLUTCH REPLACEMENT LOOK FOR PRO AND CON ON METALLIC PLATES VS FIBER PLATES HAVE LOT OF PHOTOS THAT I WILL UP LOAD TO SHOW RIPPING IT DOWN AFTER I FOUND THE MASTER PIN AND REMOVED IT NO BIG ISSUES TEAR IT FOUND THAT 4 OF THE RETURN SPRINGS WERE GONE CLEANING AND PREP TO PUT BACK TOGETHER NEED SOME FEED BACK ON PLATES THANKS
I am getting to not be a fan of the metallic plates, they are much more aggressive, harder on drivetrain, and harder on brake bands if adjusted to factory spec. If I do them myself, I adjust out of spec and run much less brake to get as little face pressure as I can on the discs. The pros are they won't swell, and should be somewhat less affected by oil, but there shouldn't be oil in there anyway.
PROS AND CONS
THANKS I HAVE LEFT YOU A VOICE MESSAGE NEED TO BUY CLUTCH PARTS GIVE ME A CALL THANKS CARY
Got your message.
whiteclipse16
Not from Deere, but aftermarket.
Users browsing this forum: Google [Bot] and 28 guests
