2010 hydraulic filter location
I have a 2010 dozer in which the hydraulics act skittish like it is sucking air.Where are the screens and filter located?
Thanks for the walk through on the phone.
I am just now getting around to the filter.I pulled the old one and filled it with solvent and it took several minutes for the solvent t leak through so I gave it a thorough cleaning but don't have it back together yet.
My local dealer has a filter for $157.
jtrichard wrote:in the trans (mid way fore and aft in the belly pan) right side 3 bolt cover also has temp sender in it
that's the way mine was packed so tight diesel would not go through it after it is cleaned you can see through the filter yes that is a pricey filter if you had to buy one ... was the seal washer still on the end of the filter?
whiteclipse16
Is there a Wix or napa or Fram filter equivalent for this. We have two 2010 wheel tractors on the farm and both have poor hydraulics. The filters have been cleaned many times but I'm wondering if it's time for a new one.
Ben
the one for the crawler is a fine steel screen the wheel I think is different.. if your takes a hard fiber (for lack of a better word) I have one that I got thinking it was the steel type that I would sell .....as far as I know no one after market makes either one
whiteclipse16
