root rake for jd 450 C
jsal
Post by jsal » Sun Jun 22, 2014 9:06 pm
any one have a rake for sale or know of one looking to purchase
JIM
hillclimber330
450 root rake rear ripper
Post by hillclimber330 » Mon Jul 28, 2014 6:22 pm
Not sure if you are looking for the ripper attachment for the back, or a root rake for the front blade. Anyway, i have the entire rear ripper assembly sans the ripper blades and slots. it is currently on a 68 450. functioning very well, no leaks. I would sell it or trade it for a winch. I will be selling the entire assembly along with the support frame that runs up under the cab. let me know if this is something you are interested in. Can send pics to anyone interested via email.
196? Deere 450 dozer 6 way blade, ripper
NWJD fan
450C root rake
Post by NWJD fan » Mon Jul 28, 2014 8:43 pm
I have a root rake/piling blade to fit a JD450C outside dozer. Only problem is it is in far Northwest British Columbia, Canada. Guessing about 2500 miles away. Shipping might cost more than having one fabricated locally.
jsal
root rake
Post by jsal » Tue Jul 29, 2014 7:23 pm
thanks for the replies, I ended up making one myself got steel from contractors steel they burnt holes in main plate I used 1 inch steel removed cutting edge left corners on added extra holes at 4'" spacing main plate is 6" high same as new cutting edge,I have 15 3/4 x 3" bolts from cat my holding the plate on tines are 3x16 with 5 '' of them welded to the main plate been using it is working well
JIM
Post by jtrichard » Tue Jul 29, 2014 9:22 pm
can you post pics of what you built?
jsal
Post by jsal » Wed Jul 30, 2014 7:54 am
will try
Post by Tigerhaze » Wed Jul 30, 2014 11:45 am
There is a thread in the "Announcements" section of the board I wrote to describe how to post photos from third party sites like Photobucket.
jsal
Post by jsal » Thu Jul 31, 2014 6:35 am
loaded photo bucket could not find link in announcements still have not figured how to post?
Post by Stan Disbrow » Thu Jul 31, 2014 7:52 am
You have to 'program' the board to show photos using two image control commands and the web address for where your photos are stored.
Firstly, you need to copy the link for your photo. For example, I have my shots on Photobucket. The link to mine is:
http://i902.photobucket.com/albums/ac22 ... D420c2.jpg
The controls for the board are Image directly after. No spaces between the commands and the link.
To illustrate, I have placed a space between the Image so you can see what it looks like. If I did not place the extra spaces, you would just see the photo.
So, now I remove those spaces:
And, there is a photo. :)
If tbat was all cryptic, Tigerhaze has a step-by-step tutorial here:
http://www.jdcrawlers.com/messageboard/ ... php?t=3690
77 Ford
Post by 77 Ford » Thu Jul 31, 2014 8:08 am
What are the odds the rippers off of the back of a straight 450 would bolt up to a 450c?
JD- 450C track loader
Serial #208336T
Post by jtrichard » Thu Jul 31, 2014 10:55 am
the ripper unit is the same (model #3110) the bracket that bolts to the tractor is the same on 450B and 450C bracket on 450 is different BUT it appears it might be able to be modified to fit a 450C though
jsal
pictures
Post by jsal » Sat Aug 02, 2014 5:18 pm
for anyone that would view how I made my rake go to my Facebook james salvatore there are 5 photos there. JIM
BEH
Re: root rake for jd 450 C
Post by BEH » Mon Jul 22, 2019 2:13 pm
I am interested in a set of rippers for my 450C
dtoots1
Re: root rake for jd 450 C our pic server
Post by dtoots1 » Mon Jul 22, 2019 2:59 pm
just so you know our "dedicated pic server" is back up.....anyone needing access to load pics needs to email Lavoy Wilcox your chosen login and password, once he acknowledges you can only access from the crawler site after you use your crawler site login, the "question and answer" forum shows up at the bottom, open that and then open "dedicated pic server" where you will find the hyper link to the server.
Post by Jim B » Mon Jul 22, 2019 3:24 pm
Welcome to the forum.
You might do well to start a new post of your own -looking for a 450c Ripper- than tagging onto this old one. People miss the dates and your current info gets muddled in the mix with the old. I would suggest you be clear on what you are looking for, such as complete ripper and mounts, etc. is your crawler inside blade, outside blade, or loader. I believe some mounts were different, someone else may respond to that point.
Adding your general location to your profile might help as well. If your in California you likely won't be interested in a ripper in Maine, so it would be a waste of time for both of us if I was to post of one here for you to look at. So travel range, or freight, to get one you would consider won't hurt to mention.
Users browsing this forum: No registered users and 305 guests
