axle
- Eric.MacLeod
axle
hello, I have the axles out of my boys 420 dozer, they are worn around the seal surface. I have seen people repair them with a reddi- sleeve and I would like to do this to.does anyone have a part number or any recommendations? thank you.Eric.
Tough to do on a 420, you have to cut the sleeve back pretty far to make sure it does no interfere with the bearing. Did it once, it just split the sleeve in two because I did not cut it back far enough.
- gregjo1948
That is what I use, pretty much only thing as far as that goes.
