Straight 350 hydrolic issues with filters
New to me 350 and still going threw everything. Read in my manual that the pion top cover comes up when oil flow is restricted. My pin is all the way up and has a roll pin through it keeping it up. So I decided to investigate. Hoping that someone just didn't change the bottom filter and the answer was to just use the bypass. Any way I pulled all 6 bolts out, however when I went to pull it out it does not pull straight up. Feels like it is caught on something in the back. Any ideas or tips? I stopped at this point and figured I would ask the pros. Thanks a head of time.
Jimmy
Jimmy
Im Addicted to John Deere's
1957 JD 420c 4 roller w/ reverser
196? JD Straight 350 Diesel 6 way blade
1945 JD B
1940 JD H
1951 JD GW
1955 JD 70D
1957 JD 720D
1959 JD 730D
1945 JD B
1940 JD H
1951 JD GW
1955 JD 70D
1957 JD 720D
1959 JD 730D
Just letting you know, your post is being read. In my case, I do not know what you are referring to. I have not had a 350 in decades, having sold mine off in the mid 90s. But, then, mine was a 68 with gear transmission and outside blade and dry clutches. I think you might be referring to something regarding the reverser, which I did not have, or maybe the wet clutches, which I also did not have. My hydraulics were tank, pump, valve and two blade cylinders.
Labparamour
- lurch85
- 430 crawler
filter
assuming you mean the hydraulic reservoir tank on your right side as you sit in the seat? (not that i have much more input, but clarifiying the questino from a previous post)
John Deere 420C, John Deere 350 straight with Gafner loader, John Deere 4020
- JPignatello
- 40C crawler
Re: Straight 350 hydrolic issues with filters
I just went through the same thing. Do not take the Roll pin out like I did. That releases the check valve into the tube below. It is just the resistance of that check valve housing coming off the tube in the tank or possibly the filter cartridge being hung up on the lip of the tank as mine was. A little pressure with a pry bar and some wiggling and it should come up.JimmyFunk wrote:New to me 350 and still going threw everything. Read in my manual that the pion top cover comes up when oil flow is restricted. My pin is all the way up and has a roll pin through it keeping it up. So I decided to investigate. Hoping that someone just didn't change the bottom filter and the answer was to just use the bypass. Any way I pulled all 6 bolts out, however when I went to pull it out it does not pull straight up. Feels like it is caught on something in the back. Any ideas or tips? I stopped at this point and figured I would ask the pros. Thanks a head of time.
Jimmy
1951 Ford F2
1996 Ford F350 7.3 5 spd
1966Chevy C60 Dump truck
1966 JD 350
1970 Ford Backhoe
1966 JD 350
1970 Ford Backhoe
can you get a pic of that rod that has the roll pin in it? it should not be up when the tractor is off.... only time it should come up is when (running) and the filter is plugged or it will come up some when very cold... it is really just a pressure gauge
