Was using backhoe on 450 straight for a while and ran transmission low on fluid. Transmission pump has leak. When I went to move machine noticed it did not want to move much so I shut it off and refilled trans. Does not want to move. Pulled pressure port plug to check pressures and have almost no flow.
It acts like pump lost its prime and won't build pressure or volume. Any thoughts or suggestions?
HLR transmission pump
I started checking all adjustments today since tractor is new to me. Turns out clutch adjustment was way off. No free play at all, adjusted it and got tractor moving again. As soon as I started tractor after adjustment I could here transmission pump running.
Will still pull engine to fix trans pump leak and will check clutch when I do pump and replace if needed.
Ya you don't want to run those power shift tranys low in oil they tend to get back at you for doing that sort of thing .Some pumps such as gear pumps have such close tolerances that they will take seals or even the main shaft out with even the slightest jolt from an air gulp taken in and can be a costly lesson in repairs .Digitup..
Users browsing this forum: No registered users and 43 guests
