450 running hot
450 running hot
I have a straight 450 and the temp runs in the red a lot, the motor was rebuilt 2 years ago, so I don't no if this is a result of the break in period, (I've only put about 25 hours on it). I put a lower temp setting t -stat to see if that helps, and a new cap, but it still runs hot. Also when I fill the radiator I loose a good amount of coolant out the overflow. Does anyone know what the problem may be? I'm thinking maybe I need a new radiator
1966 JD 450 Crawler, 1986 Case Super E Backhoe, 2001 Kubota 7800, 1986 GMC 1 ton dump truck,1991 GMC Topkick dump truck
450 running hot
Turns out it was the radiator cap, that was causing the problem
Users browsing this forum: No registered users and 40 guests
