Track pin press
JWB Contracting
Track pin press
Post by JWB Contracting » Sat Mar 22, 2014 11:47 pm
Here is a fairly low cost track pin press made for 350 and 450's. My dad had the local machinist fabricate it for him. We had the threaded rods, cylinder and pump on hand. Pressed a set of rails together and removed 2 master pins from other sets today.
It is capable of removing non master pins on a D4. Our Vermeer track plow has a very short track adjustment cylinder so we has to remove a link.
Image[/URL]
Image[/URL]
Image[/URL]
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Toomanytractors
Press
Post by Toomanytractors » Mon Mar 24, 2014 10:35 am
Nice pictures. I just built one like it, but with a third plate with a hole through it to lock it to the chain. It's designed to use a fifty ton manual jack along with different size punch bars.
How sad it is when one sees only the machine and not the artistry of heart and soul that designed it.
Post by Tigerhaze » Mon Mar 24, 2014 6:49 pm
Hi guys-
I might have missed the last discussion on that one, but can you provide some specifics about size and grade of threaded rod, cylinder rating, etc.? I am only interested in one that can push out master pins so doesn't have to be too beefy.
JWB Contracting
Specs
Post by JWB Contracting » Mon Mar 24, 2014 8:46 pm
I don't have the specs. The rods and cylinder were acquired along with surplus CN Rail rolling stock. They were used previously to pull rail road track together.
Jason Benesch
jthornton
Post by jthornton » Wed Mar 26, 2014 7:47 am
Tigerhaze wrote:Hi guys-
Are you using a bottle jack on it's side?
JT
