440 with 2-53 Detroit Diesel
JD1104x4
Post by JD1104x4 » Fri Mar 21, 2014 6:16 pm
Going to tune up a 2-53 Detroit, when you set the injectors do you use the same gauge for the S-35 and N35 injector? Also when you rebuild the 2-53 can anyone show me the engine in a stand. Do you need an adapter?
Post by Lavoy » Sun Mar 23, 2014 10:16 am
Should be the same gauge as far as I know.
Studs are likely too short to fit most engine stands, but you could pull them out and put longer ones in for the same of working on it.
JD1104x4
Post by JD1104x4 » Sun Mar 23, 2014 10:33 am
Thanks Lavoy
Dennis
whiteclipse16
Post by whiteclipse16 » Tue Mar 25, 2014 6:11 am
I second what Lavoy says. I do know that I have the N series injectors and used the tool that you're talking about for the S series and mine fires up well.
I didn't put mine on a stand because I was afraid a regular stand wouldn't hold that engine, it's heavy.
I put mine on a small cart and that worked pretty well, however I didn't do a full rebuild on it.
Ben
