I'm looking for a gasket for my john deere 450 crawler. JD said it is not available through JD anymore. DO you have an idea of where I can get one? The number is T20774. Tractor sn #T5E3M101119T I'm trying to rebuild my trans. thank you for your time.
Greg
Transmision Gasket
Buy gasket material at a parts or bearing house, it is available in many thicknesses, and cut your own. Or possibly use the blue stuff.
- 420 crawler
trans gasket
The gasket was discontinued by deere long ago,they now use a loctite gasket compuond sold at many parts stores and by deere dealers, I am not sure of the number,but I used it recently on my 450b trans case seemed to seal just fine. Remeber to only tighten those bolts to 35ft.lbs or they can break. I could tell you all about that problem. If you can't find it I can get the number next time I am in my shop. Good Luck,
There is always another rock under this one!
It is current, $20, just subs to a different number.
Users browsing this forum: No registered users and 207 guests
