I have been welding up holes in the base of my old oil bath air cleaner for this 2-53 detroit.
I was wondering if I can get some type of air cleaner that has an eliment instead of this old type oil bath aire cleaner.
where can I get it?
is there a specific model number?
how much do they run?
thanks
scott
440 icd late model air cleaner
Scott in wa.
When I bought my 440ICD/831 the air cleaner was missing. After searching around for a while one diesel shop suggested to me that I should look into a throw away filter. I am running a Baldwin PA2803. It is a pleated paper filter about 8" in diameter and about 10' long. Came complete with a metal outer shell and a rubber gromet for an outlet fitting. I took the filter to a local muffler shop and got a piece of exhaust tubing about a foot long. It fit perfectly into the filter and they expanded the other end to fit the rubber elbow that comes off the blower and replaced the steel tube that ran to the original filter. The filter lays sideways right beside the fuel tank in the area the original filter used. I built a bracket out of 3" angle iron that mounts to the two bolts that mount the fuel filter. The other arm of the angle iron supports my new connector pipe. About $20 for the filter and a couple dollars at the muffler shop. So far so good.
air cleaner
Hey thanks for the info,
I fugured that some one must have done this.
Do they work ok????
I ended up having to jb weld, tried welding but its so thin and its tough to clean and always ending up with holes that I can't see, smaller that a pin.
I will need to change it out this fall. with somthing else.
I want to go with a filter somthing like you guys have done, or have.
thanks
scott
Do they work ok????
thanks
scott
Scott in wa.
Users browsing this forum: No registered users and 234 guests
