jd straight 450 pinion gear removal
Bro.Greg
Post by Bro.Greg » Thu Mar 13, 2014 6:33 pm
I need a little info from someone who has removed the pinion from a 450 crawler before. I am having a problem removing the gear behind the first thrust washer on the pinion shaft. I have the thrust washer moved forward and the gear will not slide forward. Any ideas? Thanks
Bro.Greg
Post by Bro.Greg » Tue Mar 18, 2014 7:40 pm
update: I was able to remove the gear from the pinion shaft. I had to cut the gear into. A bearing came apart and the bearing debri seized the gear to the pinion shaft.
Users browsing this forum: No registered users and 233 guests
