1010 winch interchangeability?
- 420 crawler
Can a factory winch from a 1010 work on a 440? I figure if it doesn't bolt right up, at least you could build a custom mount and it work, right? Also wondering same thing about a gearamatic #9. Can it work on a 440?
Got wood??
1010 should bolt right on to 440, the tension rods will be the main modification you will have to make, I think they mount different on a 1010.
#9 won't fit as far as I know, wrong adapter plate.
Users browsing this forum: Hurlbutt and 226 guests
